Spinnaker: You are right in the fact that if I have a wallwart then I don't need the solar panels and batteries, but, the solar panels and battery are already in each individual light so I might as well use them. The solar lights are fine most of the time. However there are cloudy days where the solar panel doesn't charge up the battery enough. It is on those days that I would like to use the wallwart to get the lights on at night.I understand that DC is powering the lights. That is a given. Why are you using a wallwart when you have solar panels??????? There is no need for a solar panel at all then. And no need for a battery unless you wanted lights during a power failure and with those lights it should be no big deal if they were not lite during infrequent power failures.
If you need both wallwart and solar panels to make this all work then this is an awfully poor design.
