Solar LED Post Circuit Board questions
Attached are pictures of solar light and circuit board. The CB diagram I drew up I think is correct.
Measurements I took with digital multimeter:
1) Current draw from full battery is 55ma and over time voltage drops to 0.8v and the LED goes out at 4ma.
2) The voltage across the LED is equal to the battery voltage and the LED will light even if the battery is down to 0.9 volts (no load measurement).
3) Advertising ‘spec’ says with full charge LED puts out 3.6 lumens, 3300 deg K.
4) With ‘low’ battery: 60 watt bulb 6 inches away solar panel puts out 25ma and after several hours the voltage reading is 1.7 volts or better and when the battery is removed the battery itself is at 1.4v.
5) The solar light is 2 years old so I assume the LED is one of the newer ‘generation’ types.
1) Is the brown cylindrical a diode to prevent draining the battery back thru the solar panel?
2) The manual switch is used when storing the fixture so the battery doesn’t drain to ‘nothing?
3) Are my calculations for the resistor correct?
4) Inductor: Calcs correct? Is the IC switching for the inductor to work? What determines the voltage ‘boost factor’? Construction? Switching speed?
5) 50ma draw from battery: Does the voltage boost inductor decrease the ma going to the LED?
6) When the battery voltage decreases does the large ma current decrease a lot because of the ‘exponential’ relationship in the LED of volts and current or because the battery is ‘empty’?
7) Voltage across LED: Does my multimeter read only the battery voltage because it is unable to read the actual voltage because of the high ‘pulsing’ required for the inductor?
8) What does the light sensor do? Is it a ‘switch’ or does it provide power to the IC 5252F?
9) Is the light sensor also ‘protection’ to ensure the LED does not go on when the solar panel is producing voltage higher than 1.3 volts?
10) What does the 4 pin 5252F IC do in simple terms? (Pins 1-4)
11) Since volts and current are relatively low, does the battery from the digital multimeter affect the readings?
12) Any idea on how a 60 watt bulb 6” away from solar panel compares to bright sunlight?
I would appreciate any help in explaining how/what the circuit board, IC5252 does. I am assuming the ‘clear’ LED is classified as a white led. I am in the learning phase and am continuing to try to understand ‘electronics’ so that I can design my ‘modifications’.
