I am needing some advice. I have a solar furnace i have built and have come to the conclusion my little 100cfm cpu fan is not enough. I am needing about 200-300 cfm fan.
Annnny suggestions.
I need something I would rather run off a solar panel ( say a 50 watt or less) if necessary any ideas.
My other problem is i have a thermostat that needs to be powered as well.
Any ideas on how to go about this in a proper manner.
I had considered an oven hood fan if need be. Its 110 but that would ok
I have an older spare parts computer i considered using the power supply to power fan.
Annnny suggestions.
