I was wondering what your thoughts are about using the power off the solar panel to turn the motor one way (when sun is present), with a limit switch once the motor reaches its destination. Then using the battery power to push the motor the other way when there is no light, also with a limit switch to prevent the batteries from draining, maybe adding a photoresistor like solar lights have to prevent the motor from wanting to run in the other direction as well. Somehow still allowing the batteries to charge during the day... I just found http://www.evilmadscientist.com/article.php/solar , which is the perfect size solar panel, and is apparently supplying 4.5v at 90ma. Would something like this work?
