Hi, as I was trying to use buck converter before but it's really fail for me to use it (A lot of problem I faced and couldn't fix it)
So I decide to change the circuit back to something basic but trying to add something.
I want to use LM317 as Current Regulator to charging my 7.2V Battery
And want to add some feedback here, when the voltage of battery reach maximum the Transistor will work as switch to stop charging
(as picture I attach here)
The calculation will be after this as I need some advice from you
So I want to ask that do I miss something ? Should I add something for more good ?
Thanks in advance
Thanks in advance
