solar charger controller
Discussion in 'General Electronics Chat' started by ayane, Aug 3, 2009.
  1. ayane
    Thread Starter Active Member
    May 3, 2009
    39
    i was wondering if the circuit http://www.national.com/ds/LM/LM150.pdf on page 10 is able to charge a sealed gel type lead acid battery.. 12v and 4AH..
    I have 6 solar cells connected in series adding to ( voltage open circuit : 18v and short circuit current: 0.8A) ...
    was wondering whether i can use the solar cells to charge the lead acid battery using the circuit above..thx..
    Any1 can help me?
  2. k7elp60
    Nov 4, 2008
    478
    69
    Yes you could, but there are a number of circuits that are much less complicated. In fact there is an IC that is design especially for that. It is a PB137.
    The data sheet is attached.
  3. Bernard
    Aug 7, 2008
    4,230
    412
    A voltage regulator will drop to much V. With a reverse current prevention diode between panel and battery, monitor current and voltage, all you might need is a V monitor to disconnect panel when battery is charged. Max power out will be when panel is loader down to an output V @ about 7/10 of open circuit panel V. On graph V willbe about same. I X 10 = your panel +_.
  4. ayane
    May 3, 2009
    39
    thx for all your help..i start to patch the circuit..
    By the way, was interested to know whats the minimum input voltage to this PB137 IC?..
  5. k7elp60
    Nov 4, 2008
    478
    69
    If you mean for it to regulate the output for charging a 12V battery: Then the answer is about 15 volts. The data sheet has several charts that show the performance of the IC.
  6. ayane
    May 3, 2009
    39
    1. hey thx for the help...I was wondering how can i add protection features to this circuit?..
    Or some features such as detecting whether the solar cells are providing enough voltage or current to charge the battery?...
    Eg: http://www.circuit-projects.com/dimg/12V-lead-acid-battery-discharge-indicator.gif
    2.I had also found a circuit which charges a 12v lead acid battery..
    http://ludens.cl/Electron/12Vcharger/12Vcharger.html but the problems lies the low efficiency about 50 percent..
    Any suggestions on how to improve the efficiency?.
    3. Lastly i am not quite how sure the charger circuit below works..Any can help me thx?
    The circuit http://www.national.com/ds/LM/LM150.pdf on page 10 is able to charge a sealed gel type lead acid battery.. 12v and 4AH..
  7. ayane
    May 3, 2009
    39
    Anyone can help me? As i am a bit lost. By the way i am doing this for my school project.
  8. fanie
    Jan 20, 2007
    63
    Ayane,
    The first thing kids should learn at school is not the facts - that one can learn any time in your life. The first thing they should learn you is how to do things for yourself other than being spoon fed. If you don't learn that then you are always going to be depending on someone else.
    Read up on it then post back when you think you have a solution.
  9. ayane
    May 3, 2009
    39
    I had read up about it hmm not sure what i intepret is correct.
    I think the operation amplifier is comparating the voltage of the battery with a reference voltage based on the term hysterisis?
    The reference voltage is set by the 3 resitor R2, R3, R4?..
    The diode act as a protection from reverse-flowing of the battery
    R6 will be the current sense resistor of the battery..
  10. Bernard
    Aug 7, 2008
    4,230
    412
    As suggested on page 3, did you measure charging current & voltage with every thing connected? For protection try a 14V shunt regulator.
