Solar Charger Battery Replacement.
Discussion in 'The Projects Forum' started by yltan, May 21, 2009.
  1. yltan
    May 21, 2009
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    The link does not work.
    Greetings,
    Bertus
  3. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    On the page you gave it says:
    The term polymer in this probably means that a lithium polymer battery is used.
    This can not be replaced by an other type of battery.
    The way of charging for lithium battries differs from NiCd and NiMH.
    For more info take a look at the "batteryuniversity"
    http://www.batteryuniversity.com/
    Greetings,
    Bertus
  4. yltan
    May 21, 2009
    What if I replace it with polymer battery instead? I mean by removing the existing battery and replace with higher capacity. Reason for replacing with higher capacity is that when I opened up the casing to see the built in battery as I suspect the built in battery is not what it claim to be 1350mAH. The size of the built in battery is so tiny (1cmx2.5cm x0.4cm).
  5. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    I do not know how "intelligent" the charger is.
    A higher capacity battery will take a longer time to be charged fully.
    I do not know how the charger will react on the larger capacity.
    Greetings,
    Bertus
  6. yltan
    May 21, 2009
    I am aware that it will take longer time to charge. I just need to increase to larger battery capacity.
  7. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    Here is a quote from the battery university about the lithium polymer batteries:
    The battery was probably special made for the charger.
    Greetings,
    Bertus
