I have two calculator solar panels connected to two rechargeable batteries, which are in a Gameboy color. I also have a diode that controls the flow towards the batteries, from the solar panel. As I am writing does the diode have to be connected to the negative wire to direct the flow correctly?
Gameboy color
Minimum voltage 2.4
Minimum amps .3
The rechargeable batteries
Info from the charger
Input Voltage 5VDC
Output Votage 1.4VDC
Charging Current 200mA
Solar panel info
What I got form the multimeter
Output Voltage 3.83
Amps .011mA
with the info I believe that I am not producing enough amps, is there a cheap way to increase the amperage?
Gameboy color
Minimum voltage 2.4
Minimum amps .3
Input Voltage 5VDC
Solar panel info
Output Voltage 3.83
Amps .011mA
