Solar charge / controller
Discussion in 'The Projects Forum' started by jboavida, Jul 22, 2009.
  1. jboavida
    Jul 10, 2008
    23
    Hi All,
    I'm planning to build a solar charger / controller and I need some sugestions / advice.
    The working principle is simple: A microcontroller (AtTiny25) monitors the battery voltage and switches the Solar panel with a PWM signal via a mosfet transistor. A second mosfet controls the load. If the battery is below a certain level the load is disconnected, so the battery does not run flat.
    My question is concerning the PWM signal. Should I vary the duty cycle accordingly to the battery charge level? or should I shoul I mantain the duty cycle and switch on an off only?
    Thanks in advance for any help
    Joaquim
