Solar Charge Controller Circuit
Discussion in 'The Projects Forum' started by sonar_abhi, Apr 26, 2016.
  1. sonar_abhi
    Mar 19, 2016
    16
    Hello All,
    I have been designing a solar charge controller for 12 volt battery. The circuit is shown below. The parameters of the buck converter are as follows:
    D1: Schotkey diode MBR1645
    L: 8uH
    Ci: 470uF
    Co: 2000uF
    Can anybody please validate the above design. The parameters are as follows:
    Vin(min): 15V
    Vout: 12 V
    Iout: 15 A
    Switching Frequency: 50kHz
    Iripple: 30%
    Vripple: 10%
    The 1kHz PWM wave feeds the Dickson Charge Pump for driving the gate of the IRF44Z.
  2. wayneh
    Sep 9, 2010
    12,396
    3,246
    You should learn to use LTspice. It can simulate your circuit for you and also produce a schematic that's easier to read. It has a learning curve but will save you time in the long run if you're designing circuits.
  3. Dodgydave
    Jun 22, 2012
    5,161
    772
    Where's the 12v feed coming from on the left?? Dont see the point of the two transistors back to back...
  4. Alec_t
    Sep 17, 2013
    5,979
    1,138
    There is nothing shown for monitoring either the battery voltage or the charging current. How will you know what PWM duty cycle to generate in order to control the charging?
  5. wayneh
    Sep 9, 2010
    12,396
    3,246
    And once you have proper control over the MOSFET, I think D1 becomes redundant and an unneeded power loss.
  6. crutschow
    Mar 14, 2008
    13,509
    3,385
    I also suggest learning LTspice (free download from Linear Technology) to simulate your circuit.
    It has a fairly steep learning curve but the tutorial and examples will greatly help, as well a help from several of us on this forum.
    Simulating your circuit will save you a lot of grief in getting it to operate after you build it.
  7. sonar_abhi
    Mar 19, 2016
    16
    Will try and learn LT Spice (already downloading it)
    @ Alec_t,
    I am controlling the PWM with a micro controller that tracks the voltage of the battery via a voltage divider (not shown in the circuit diagram)
    Also, the voltage and and current of the panel is monitored via a voltage divider and a current sensor (also not shown in the circuit diagram)
    When the voltage of the battery is below 14 V, the PWM is at maximum duty cycle which charges the battery at Vmp of the panel. When the battery voltage rises upto 14 V, the duty cycle is reduced so as to keep the battery at trickle charge.
    At the same time, a P&O algorithm monitors the panel power and if the panel is being loaded, it adjusts the duty cycle to keep the panel at Vmp.
    @wayneh, D1 is included it so as to protect the battery in case the panel voltage drops suddenly (even if for a small time due to clouds passing over and the monitoring sequence has just completed) In such a case, the current might flow from the battery to the panel and can damage it. I know it sounds far fetched but wanted to be safe. This is precisely the reason I am asking the community for help. If you think if is redundant, please explain the logic so that I can remove the component and improve the circuit.
  8. wayneh
    Sep 9, 2010
    12,396
    3,246
    Never mind. In the normal configuration with the source pin to the right in your drawing, the body diode would allow conduction in the reverse direction, if not for D1. I was confusing this with some work I did on an active rectifier a while back, where you turn the drain and source around and use forward conduction through the body diode to your advantage. Not relevant here.
