Solar Battery Comparrison
Discussion in 'General Electronics Chat' started by Knowlittle, May 7, 2016.
  1. Knowlittle
    Mar 16, 2016
    45
    why does a solar cell (18-21v) have less "power / amp" than a 12v battery ?
    Please guys / gals, MAKE IT SIMPLE !
  2. nsaspook
    Aug 27, 2009
    3,006
    2,349
    Tell us what you think about it.
  3. Knowlittle
    Mar 16, 2016
    45
    It doesnt make sense !
  4. Knowlittle
    Mar 16, 2016
    45
    Why now would an 18-21v (.56amp)solar panel have less amp than a 12vac (2.16amp) battery ? See this is what makes no sense !
  5. Alec_t
    Sep 17, 2013
    5,956
    1,131
    The major factor determining the current they can provide is the effective internal resistance of the two things. The lead-acid battery has a lower resistance than the panel, so is able to provide a higher current. However, note that the 2.16A spec for the battery is the maximum allowed initial charging current; not the current it can provide. You are comparing apples with oranges.
  6. Knowlittle
    Mar 16, 2016
    45
    Then what is the batteries amps ?
  7. Alec_t
    Sep 17, 2013
    5,956
    1,131
    Could be 100A or more (for a short time!). That's just a guess. It is the connected load which determines the current. Ask the manufacturer what the maximum current draw is.
  8. ErnieM
    Apr 24, 2011
    7,434
    1,625
    By "power / amp" I assume you mean either power or amps (or current), as "power / amp" is equal to volts.
    Power can be calculated by P = I*E (power = voltage * current)
    The solar cell is rated for 18V when drawing .56A under full sun or such. 18V * .56A = 10.08 Watts
    The battery will supply 13.5V at 2.16A initially. 13.5V * 2.16A = 29.16 Watts
  9. hp1729
    Nov 23, 2015
    2,071
    230
    Light doesn't provide as many current carriers per volume than a battery and solar cells only convert a fraction of those.
  10. wayneh
    Sep 9, 2010
    12,368
    3,224
    First, it depends on the specific cell and battery. I'm sure I could find a panel and a battery that would show the opposite relationship.
    But the basic answer is that you may be confusing voltage and amperage capacity. They are two very different things. Voltage is called an intrinsic property, it does not depend on scale. Cells in a lead-acid battery each develop the same voltage regardless of size. Solar cells are similar - the voltage they can reach depends on their makeup and construction.
    Amperage capacity is an extrinsic property. It depends completely on scale. A typical car battery has hugely more capacity than a little AA, or even 8 of them in series (to give 12V). You don't want to start your car with just any 12V battery, you need a big one! Same with solar panels, if you need a lot of power you'll need a large panel.
    A battery is very energy dense - a lot of power in a small package. Solar energy comes to us in a very diffuse way. We need a large panel to collect and concentrate the power.
    Knowlittle likes this.
  11. Knowlittle
    Mar 16, 2016
    45
    Ok thanks. So here is another question....the motor ALMOST wants to run with this solar panel, is there any type of circuit a person can build that would "streamline" the output of the solar panel in order to make the motor turn ?
  12. hp1729
    Nov 23, 2015
    2,071
    230
    More solar cells in parallel to supply more current.
  13. ErnieM
    Apr 24, 2011
    7,434
    1,625
    Motors are particularly difficult for solar panels to run because they have a high initial starting current, and when you try to pull too large a current from a solar panel the voltage drops, and can dr to near zero.
    So when you attach a motor it draws this large current, the voltage goes low, which means the power is near zero also, and all you do is pump a large current thru your stalled motor.
    A battery in the middle works great as they can supply high currents for brief times no problem. Some schemes use a capacitor for a kick start of current too, but you typically need a large cap for this task.
    What size cap depends on how much and for how long you need that current. Do you know that?
