solar battery charger..
Discussion in 'The Projects Forum' started by RRITESH KAKKAR, Nov 30, 2013.
  1. RRITESH KAKKAR
    Thread Starter Senior Member
    Jun 29, 2010
    2,831
    89
    I need a way for developing project for charging 4 12V battery of electric scooter from solar panel please suggest just for proto type model ....how it should be done????
  2. wayneh
    Sep 9, 2010
    12,403
    3,250
    Start with an energy balance. How much energy does a complete charge require, at what voltage (12V or 48V)? Your solar panel will need to supply roughly double that amount of energy, in whatever time you are willing to wait for charging, given the available hours of sunlight.
    My hunch is you'll see that's a larger PV panel than you may have thought, and perhaps too expensive and impractical. But that's your decision.
  3. Bernard
    Aug 7, 2008
    4,246
    423
    Some figures for comparative use:
    REC230AE panel, OC 36.9V, SC 8.6 A, max pwr. 29 V, 8 A, 65.5 in X 39 in. 2 panels in series 58V, just about right for charging 48 V battery [ high noon, clear day]
  4. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    any other way of charging battery??
  5. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Is there anyway of making 12V to 48V converter ..??
  6. wayneh
    Sep 9, 2010
    12,403
    3,250
    Yes, there are all sorts of DC-DC converters out there. Look on e-bay, of instance. Some are even meant for properly charging a battery. Of course the more features you want, and the larger the specifications, the more such a thing will cost.
    You can make a converter starting with the right IC, but it is a moderate project, not big but not simple either.
  7. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Yes so, tell any circuit for making it?
  8. shteii01
    Feb 19, 2010
    3,516
    515
  9. RamaD
    Dec 4, 2009
    254
    33
    What is the Ampere Hour capacity of the battery? What is the time in which you would like to charge the batteries?
    These are important parameters, which have been stated by Wayneh, and Bernard's suggestion assuming reasonable values of these parameters.
    You cannot get a small panel giving 12V, maybe 500mA, and hope to charge the batteries in reasonable amount of time, with a 48V boost converter.
