Is that true, once you factor in leakage? They're much more efficient than a battery if long leakage times are not involved, but they are in this application....extremely efficient...
I don't know, I still think that Deep cycle batteries are going to whoop the super capacitors buttocks cost-wise.What about using a super capacitor bank? No charging IC's to deal with, extremely efficient, no memory effects, and long life. I highly doubt anyone would get 5 years off a solar array on any sort of battery chemistry.
+1I don't know, I still think that Deep cycle batteries are going to whoop the super capacitors buttocks cost-wise.
Battery Charging IC: BQ24400 ( LED Driver IC: TPS61042 On...esign and test one both ways to see who wins.
I appreciate the comment, but the decisions for this sort of project needs thorough research so just posting numbers like that aren't super helpful.i appreciate your work..
i think input:5V/800mA, Output:5V/500mA,
battery capacity, 2400mAh that should me perfect..
I was skeptical that caps are a good option. I still question the capacity per dollar. But I happened to leave a big electrolytic charged to about 90V last night and found it at 75V this morning. I guess that's a lot better than I expected. Storing a charge for a few hours overnight is doable. Still, batteries are better at delivering their power at a near-constant voltage, and can store so much more in less space for less money.Is that true, once you factor in leakage? They're much more efficient than a battery if long leakage times are not involved, but they are in this application.
Batteries are the most likely route for our application, but we do need to have a few different prototype ideas in order to validate the one we chose so it's work looking into. Plus you never know what you might find.I was skeptical that caps are a good option. I still question the capacity per dollar. But I happened to leave a big electrolytic charged to about 90V last night and found it at 75V this morning. I guess that's a lot better than I expected. Storing a charge for a few hours overnight is doable. Still, batteries are better at delivering their power at a near-constant voltage, and can store so much more in less space for less money.
Thread starter | Similar threads | Forum | Replies | Date |
P | Solar powered battery charger | Power Electronics | 5 | |
C | 12V solar panel to 3.7V li battery charger | Power Electronics | 16 | |
battery-Solar charger | Power Electronics | 18 | ||
H | Solar Battery Charger Tips Request | Power Electronics | 1 | |
H | Diode for solar-car-battery-charger (protection while starting the car) | Power Electronics | 4 |
