Solar battery charger w/ load, first time building a circuit
Discussion in 'The Projects Forum' started by Атанас Баротов, Dec 25, 2015.
  1. Атанас Баротов
    Oct 7, 2015
    18
    Hello everybody, this is my first time building a circuit and I'm trying to figure out exactly which transistors I should be using as well as diodes and everything else relevant. The Arduino will control when a battery gets charged or not via the digital pins (5v output). Here's the schematic I have so far.
    I've been experimenting with a few transistors that I had, but either they get hot when i put a DC motor or they don't fire at all at 4v. The A0/A0 ports are to detect the battery voltage. The buck up/down circuits are ones i've purchased from ebay so they should be ok. The solar panel is about 400mAh, 7v and the batteries are 3.7v LiPo, 9900mAh
  2. ISB123
    May 21, 2014
    1,240
    531
    TIP120 Transistor should be fine.BY550/1000 diode would be fine.
  3. Атанас Баротов
    Oct 7, 2015
    18
    Thank you - gonna try those as soon as the store opens :)
  4. spinnaker
    Oct 29, 2009
    5,078
    1,180
    Why are you bucking up to 10V and down to 4 v?
    Charging batteries properly is a science. You might want to read up at the Battery University.
  5. spinnaker
    Oct 29, 2009
    5,078
    1,180
    Must be nice to have a local shop where you can buy components. ;)
  6. Атанас Баротов
    Oct 7, 2015
    18
    Well, it was suggested to me to have it boosted to 10v and then down as the solar panel outputs from 3 to 8v, but changing that is the easiest parts as both the boost up and the buck down circuits have regulators and I can try removing one.
    Yeah, having a local store is nice, though half the time they dont have exactly the component you need :)
  7. spinnaker
    Oct 29, 2009
    5,078
    1,180
    How much voltage are you getting out of your panel?
  8. Атанас Баротов
    Oct 7, 2015
    18
    usually about 4-5v. Haven't done extensive testing there. According to specs it should be: 6v, 3.5W, 580-600mA though direct sunlight tests have shown voltage above 7-8v
  9. wayneh
    Sep 9, 2010
    12,389
    3,245
    I really don't think you need either converter, just a charge controller. Those converters are just wasting power. You should check, but I think your battery can take the full current from your panel. You just need to stop it from overcharging the battery, to stop when it's done.
  10. Атанас Баротов
    Oct 7, 2015
    18
    It's said that the battery life (max charge cycles) decrease if I feed it more energy (about 2000 at 4v, 500 cycles at 4.2v). The whole point of this is that I can control when a battery get charged via the arduino
  11. wayneh
    Sep 9, 2010
    12,389
    3,245
    Yes but do not confuse the battery voltage with the higher voltage potentially available from the charger. The higher voltage of the charger only matters if 1) it causes too high a charging current, or 2) is allowed to overcharge the battery to too high a voltage.
  12. Атанас Баротов
    Oct 7, 2015
    18
    the analog pin of the arduino can take only up to 5v so the buck down module is mandatory
  13. ISB123
    May 21, 2014
    1,240
    531
    Or you could use a voltage divider.
  14. wayneh
    Sep 9, 2010
    12,389
    3,245
    And maybe also put a 5V zener on it to protect it from over-voltage input.
  15. spinnaker
    Oct 29, 2009
    5,078
    1,180
    You will need to use a voltage divider if you want to measure the voltage of the panel. Design the divider so you have enough resolution so it can be accurately measured but also so the divided voltage does not exceed the capabilities of your mcu, In other words design it a bit beyond the maximum voltage your panel will put out. With a buck regulator you will get a constant voltage.
  16. GopherT
    Nov 23, 2012
    6,315
    4,037
    Two resistors in series is much easier.
  17. Атанас Баротов
    Oct 7, 2015
    18
    Thanks, I'll try a version with the 50% voltage divider, though, is that much power lost in the conversion that I should try to avoid that buck down module?
  18. spinnaker
    Oct 29, 2009
    5,078
    1,180
    As I already mentioned, a step down regulator is not going to work if you want to measure voltage level. A step down regulator is in fact a regulator so it is going to attempt to maintain the voltage to which it is designed till it passes it's minimum operating voltage. Even then the change might not be a true representation of the change at the input because of the circuitry in the regulator.
    All you would know is the voltage level dropped below it's operating voltage. If that is the way you want to go then there are better ways to do it like using a comparator. Then all you need to do is use a binary input to test the output of the comparator..
  19. Атанас Баротов
    Oct 7, 2015
    18
    Something like this?
  20. spinnaker
    Oct 29, 2009
    5,078
    1,180
    That schematic could be drawn a whole lot better but yes. Do you want to monitor the two batteries individually?
    There is something odd to me about those transistors. It looks to me like you are trying to shut off the step up regulator.
    Here is a nifty calculator to help out.
    http://www.raltron.com/cust/tools/voltage_divider.asp
    Oh and you do want a step down for your supply to your MCU.
