Sola 'power supply'
Discussion in 'General Electronics Chat' started by mrmeval, Jul 8, 2007.
  1. mrmeval
    Thread Starter Distinguished Member
    Jun 30, 2006
    833
    I picked up a ferroresonant power supply capable of putting out 120V at 16.5 amps. These are sometimes called 'Line stabilizers'.
    But other than using it on my PC or an appliance I can't think of anything it's useful for.
  2. cumesoftware
    Apr 27, 2007
    1,330
    11
    You could use two of those in Europe. Primaries in series and secondaries in paralel. LOL
  3. mrmeval
    Jun 30, 2006
    833
    I think you'd have to remove the capacitors then.
    I was looking at the schematic of one and wonder if you can actually use the winding the capacitor is on for an output if the capacitor is removed.
    BTW this thing has a lot of capacitors for the resonant winding.. I'll need to crack it open to count them. The transformer itself is about a 1 foot cube. It all weights around 100 pounds. That's 50 British pounds.
    *snicker*
  4. cumesoftware
    Apr 27, 2007
    1,330
    11
    I think if you remove the capacitors, you would have a problem. The capacitor is there to "regulate" the voltage in the other secondary. The capacitor is calculated according to line frequency and the secondary impedance. Just use the other two secondaries of the respective power supplies tied together.
    See this: http://www.mcitransformer.com/i_notes.html
  5. vinnygalbo
    Aug 28, 2008
  6. KMoffett
    Dec 19, 2007
    2,584
    234
    My experience is that these are designed to regulate the average output voltage, with the rated load, under slowly varying line voltages. Regulation is not as good when lightly loaded. Also the outputs can "ring like a bell" when there are high current inductive loads being switched on-and-off on the same circuit that the primary is plugged into.
    Ken
