SOLA Power Supply
Discussion in 'General Electronics Chat' started by pujulde, Aug 25, 2015.
  1. pujulde
    Jul 24, 2013
    95
    Hi, I have SOLA Power Supply. When I switch it on with load it does not work. If I turn it on without load and after connect ones it works good. Can anybody give some advice? Thanks in advance. IMG_20150825_133551.jpg
  2. Dodgydave
    Jun 22, 2012
    5,138
    767
    Looks like there's burning on the top diodes, do you have a circuit diagram or model number of the psu...
  3. pujulde
    Jul 24, 2013
    95
    I checked them and they are OK. The model is SOLA SDN 5-24-100p. I could not find schematic diagram.
  4. alfacliff
    Dec 13, 2013
    2,449
    428
    check the low ohm high watage resistors, one is to measure current for over current protection. I have found those burnt before. its a switching supply. check the setting of the over durrent adjustmentl.
    pujulde likes this.
  5. pujulde
    Jul 24, 2013
    95
    The place where the powerful resistor of 100 ohm installed is burned, but the resistor was good. Despite this I replace it with new one. The same problem.
  6. alfacliff
    Dec 13, 2013
    2,449
    428
    look for several large surface mount resistors next to eachother. low ohm value.
  7. pujulde
    Jul 24, 2013
    95
    OK, I will try, but I think there is not
  8. pujulde
    Jul 24, 2013
    95
    I could not repair, its bad. Thanks for help
