SOIC breakout board needed
Discussion in 'General Electronics Chat' started by ElectronicsNoob, Jun 27, 2013.
  1. ElectronicsNoob
    Jun 27, 2013
    Hello all,
    I have to use a 555 with an SOIC footprint on a breadboard. Does anyone know of a cheap place to buy soic breakout boards?
    Thanks!
  2. Veracohr
    Jan 3, 2011
    560
    77
    Not cheap, but look up Schmartboard.
  3. shortbus
    Sep 30, 2009
    4,098
    1,697
  4. mcgyvr
    Oct 15, 2009
    4,794
    978
  5. ErnieM
    Apr 24, 2011
    7,443
    1,628
    I hate paying a lot of money for adaptors... plus I like the leads to come out on 0.1" centers. I get lots of 2-sided adapters thru EBay from China, like these:
    Different pattern on each side, dirt cheap... shipping takes 2-3 weeks so I lay in a stock.
    That image is from a place called "uincelec," search them if you wish. 20 pieces are $4.99USD free shipping worldwide.
    I have yet to use that particular vendor, I previously used dig-ole but they got a little pricey.
  6. kubeek
    Sep 20, 2005
    4,691
    806
    1.27mm pitch devices are easy, you bend every other pin upwards and solder the remaining to their pads on a normal 2.54mm protoboard, and use wires to solder the rest of the pins. I also did a few 0.8mm and 0.65 devices like this up to 14 pins each, but that was a real PITA.
  7. bance
    Member
    Aug 11, 2012
    315
    34
    You could solder wires to the pins and then use an IC holder....
  8. GopherT
    Nov 23, 2012
    6,339
    4,085
    That is not easy and not durable.
  9. THE_RB
    Feb 11, 2008
    5,435
    1,305
    But that does work ok if you solder 4pin single headers into
    the holes. Then you have a "DIL IC" that can be plugged into a breadboard etc. :)
