Software requirements for PIC
Discussion in 'Embedded Systems and Microcontrollers' started by mukesh.sehwag, Aug 29, 2012.
  1. mukesh.sehwag
    Oct 16, 2010
    7
    I was using a software for programming(PIC) but it doesnot work n Win 7. If anybody can suggest a software which works in Win7 along with a simulator software for Win7.
  2. Markd77
    Sep 7, 2009
    2,803
    594
    MPLab X should work with Win 7.
    mukesh.sehwag likes this.
  3. JohnInTX
    Jun 26, 2012
    2,391
    1,051
    I'm using it as I write with Win7-64 Pro but if you are starting out, use MPLAB X as suggested. It works fine with Win7.
    Caveat: some legacy third party software has trouble with Win7-64. For example, HiTech PICC-18 8.35xx does not properly report errors through MPLAB 8.xx with Win7-64.
    While Microchip development tools/software/hardware have had occasional issues, its still the way to go IMHO.
  4. nigelwright7557
    May 10, 2008
    488
    71
    I use MPLAB 8.86 ok with Win 7 64 bit and have no problems.
    I still use the old MPLAB coz I have a PICTSTART programmer taht is not supported under MPLAB-X
  5. mukesh.sehwag
    Oct 16, 2010
    7
    Thanks for your help, it worked. I am just planning to do a project which uses - "at commands". Can anybody tell from where I can get those commands. I want to learn it for my project.
  6. debjit625
    Apr 17, 2010
    790
    186
    What do you mean by "at commands" ?
    More info will be helpfull for us.
    Good luck
  7. mukesh.sehwag
    Oct 16, 2010
    7
    AT commands are used to control MODEMs like GSM modem. What I have learnt from others, these are some command lines which were given to the MODEMs to do some work for example sending message through GSM MODEM or making call to a number.
  8. madhusuthanan
    May 30, 2012
    5
    for sms through modem.
    at+cmgs="mobile number" <enter> message <ctrl+z>
    for call
    atdmobile number
