Soft Starter.
Discussion in 'General Electronics Chat' started by R!f@@, Dec 10, 2013.
  1. R!f@@
    Thread Starter AAC Fanatic!
    Apr 2, 2009
    8,792
    771
    I am planning to make a soft start circuit since the Tranny I intend to use in my Big Daddy PSU is tripping my 10A CB. :mad:
    The Tx is around 2000VA. It has 4 windings of 60V capable 8.3A Continues.
    My PSU will have 4 outputs, all isolated so I can series them and parallel them if needed. :D
    My question is simple.
    What will you use for the series power resistor tht limits the inrush current.
    I thought of series connecting 4 X 10Ω10W . So 40Ω 40W.
    Will it do. What will u recommend for the delay time. 1 sec or more.
    The smoothing caps will be 10,000μf . per winding.
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
  3. ScottWang
    Aug 23, 2012
    4,933
    777
    Are you affraid of the current reducing by the limiting resistor, although the capacitor 10000uf could store the energe on itself, the load need the continuing current, but that will stop by the resistor, so you have to considering the voltage drop.
    Maybe you can using the Magnetic Field of Toroid to replace the resistor.
  4. inwo
    Nov 7, 2013
    2,435
    315
  5. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Toroidal transformers should have a series resistor added to the primary winding circuit to reduce the extremely high inrush current.
    The ratio of inrush current to operating current is so high that you don't need a fancy solution, just drop 2-3% of operating power in the resistor which has little to no noticeable effect on normal operation besides dissipating a couple watts in a 10W resistor.
  6. #12
    Nov 30, 2010
    16,704
    7,354
    Here are a couple of educational pages for NTC surge limiters.
  7. t06afre
    May 11, 2009
    5,939
    1,222
  8. R!f@@
    Apr 2, 2009
    8,792
    771
    Well..! u guys are off the point.
    I know how to make one.
    My question is what would be a feasible value series resistor for the primary in rush current limiter.
    I never tried for a 2000VA one. I can make one for 500VA one.
    But for the 2000VA one the resistor needs to be powerful and different value.
    I wanted to try with a 40ohm 40W one. Will it be suitable or blow.
    My Supply has inrush limiter with a bypass relay at the secondary side.
    My problem is tht the CB trips sometimes even with the transformer alone. The damn thing is heavy. I can barely lift it.
    I got it from a peavey 2000 amp.
    RB got close to what I wanted to know.
    2 to 3 % drop. OK lemme do some calculation
    Oh and um tranny is an EI one
  9. t06afre
    May 11, 2009
    5,939
    1,222
    Try Google and <transformer soft start> or <transformer softstart> The Elliott Sound Products site give a decent explanation about this topic
    Edit: Would it not be more easy to just rip the inrush protection unit from the peavey 2000 amp
  10. R!f@@
    Apr 2, 2009
    8,792
    771
    I got the basic idea from Elliott.
    Peavey does not have the stinking limiter.
  11. t06afre
    May 11, 2009
    5,939
    1,222
    Perhaps it just used a NTC in series with the primary?
    R!f@@ and shortbus like this.
  12. R!f@@
    Apr 2, 2009
    8,792
    771
    Now u have said tht..! :confused:
  13. THE_RB
    Feb 11, 2008
    5,435
    1,305
    NTC surge limiters function better than a simple resistor, but have a much higher incidence of fail.
    Like I said, when the ratio of inrush current to operating current is very large, a resistor of the right value works quite well. If that ratio is lower then a thermistor will work the best.
  14. MikeML
    Oct 2, 2009
    5,451
    1,066
    And it works even better if you eventually short the resistor with a switch or relay.
