Soft start for power amplifier
Discussion in 'The Projects Forum' started by williamthomas, Aug 4, 2013.
  1. williamthomas
    Jul 26, 2013
    17
    Hi i have an idea how this soft start works, but can i have a clear explanation?
    That would be great. Thanks.
  2. tubeguy
    Nov 3, 2012
    1,157
    197
    A linear power supply will typically have some large filter caps which draw a large current for a short time when power is first applied.
    The thermistors provide a resistance to limit this inrush current when AC power is first applied. The thermistors resistance will then drop as current is drawn through them, but there will still be a small resistance.
    That's were the relay circuit comes in. The 24 volts DC charges the 470uf capacitor through a resistor, after quite a few seconds the transistor will be turned on which will turn on the relay. The relay contacts close and are intended to bypass the thermistors. But, the schematic as drawn has an issue, The relay contacts are drawn incorrectly. They will short out the mains and the transformer primary :eek:
    The respective contacts should be wired in parallel with each thermistor.
    This is a nice feature because it removes the resistance of the thermistors. Otherwise this resistance would cause an unwanted voltage drop when the power amp is operating.
    BTW. Did you have any luck with the power amplifier ?
  3. williamthomas
    Jul 26, 2013
    17
    Nice thanks. the RC network is about 30 sec. this is the time that is specified in the data sheet for the thermistor. i have made some changes to the attached circuit. is it correct now?
    I got help with the power amplifier and i am now ready to do the pcb with EAGLE. the power amplifier is for my final school project.
  4. LDC3
    Apr 27, 2013
    920
    160
    You still have a problem with the mains circuit. When the relay closes, I can connect both mains connections without any resistance. Also with the transformer connections. I believe you need to change the relay for a DPDT type.
  5. LDC3
    Apr 27, 2013
    920
    160
    I believe that this is the circuit you want for the mains side of your drawing.
  6. williamthomas
    Jul 26, 2013
    17
    the relay that i have is omron g2rl-2. it says that it's a dpdt. are my connections then okay?
    farnell link is: http://dk.farnell.com/omron-electro...c/relay-pcb-dpco-12vdc/dp/9950176?Ntt=3650585
  7. tubeguy
    Nov 3, 2012
    1,157
    197
    You need to make the connections using the NO contacts as shown by LDC3 in post #5. Your relay type is fine.
    But the coil voltage is 12VDC. If you want to run it using 24VDC then you should put a resistor in series with the coil to drop the voltage. Since you need 1/2 the 24 volts, a resistor close to the relay coil ohms (360) would be fine. A 330 ohm would be OK. I suggest the resistor should be at least a 2 watt rating. The dissipation will be ~ 0.4 watts. A 1 watt would work but get quite warm.
  8. Ron H
    Apr 14, 2005
    7,050
    657
    Why would you need two thermistors?
  9. williamthomas
    Jul 26, 2013
    17
    i spoke with my class mate and he thought that two thermistors will be fine. i thought that only one thermistoris necessary for the inrush current. now i have to figure out how to connect it with a relay.
  10. #12
    Nov 30, 2010
    16,705
    7,358
    It goes like this:
    (assuming the values in the original circuit are valid)
    For the nit pickers: it's a concept drawing. It can be turned into a schematic by adding the part numbers and values.
    You can use one or two thermistors, depending on what you can buy and how much current/power each one can survive.
    The 68K resistor has been balanced to the gain of the transistor and the load current. If it was trying to do a saturated switch at 3.33ma, it would use up 226 volts. Forget the 360 ohm resistor and adjust the 68K to get the voltage on the relay right.
    Don't forget to add a fuse.
    I don't know what, "TRAFO" means, so I faked it.
  11. williamthomas
    Jul 26, 2013
    17
    What about now? i've attached the circuit.
  12. LDC3
    Apr 27, 2013
    920
    160
    Damn, it's my own fault for not labeling my figure. :eek:
    What does the 230V supply power in your circuit? As far as I can see, only the RTC. It does not connect to the rest of the circuit. You probably want one line of the 230V to go through the RTC and onto the transformer primary coil and the other line to do the same.
  13. williamthomas
    Jul 26, 2013
    17
    the 230v is the mains power.
  14. #12
    Nov 30, 2010
    16,705
    7,358
    Be sure to see my correction in post#10. The relay driver is a finicky circuit.
  15. williamthomas
    Jul 26, 2013
    17
    trafo means transformer. see my edited circuit on page 3 of the thread.
  16. #12
    Nov 30, 2010
    16,705
    7,358
    Here is a different way to make a delayed relay driver, or you could use an op-amp, or a mosfet or a j-fet, if you know how to design that sort of thing.
