"soft start" audio fade
Discussion in 'The Projects Forum' started by timburly, Feb 1, 2011.
  1. timburly
    Feb 1, 2011
    Hello all,
    I am working on an audio project and am having a hard time finding any ideas on schematics. I am trying to build a simple circuit that will fade in music upon a switch closure. When the switch is open there is no audio. When the switch is closed the audio fades in from nothing to a preset limit. This fade in period needs to take about 1 minute.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. Bernard
    Aug 7, 2008
    4,231
    414
    Might be able to use analog opto-coupler as volume control. Need to then provide a variable 0 to 20 mA drive to input LED.
  4. Bernard
    Aug 7, 2008
    4,231
    414
    After thought: Not tried or simulated but might work. Q1 is darlington transistor to give high impedance load on C1. Vary R2 & or C1 to give desired slope. LED & R4 is analog opto-coupler or home built. R3 to suit LED-around 470Ω for IR LED.
  5. wayneh
    Sep 9, 2010
    12,368
    3,222
  6. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,383
  7. timburly
    Feb 1, 2011
    Thanks for the reply guys...a Digikey order has been made and looks like I will be bread-boarding until I figure this out.
  8. hgmjr
    Jan 28, 2005
    9,030
    214
    One technique that could prove effective would be to design your audio amp and then on the input use a digital potentiometer in the volume control circuit. That way you could use a 555 oscillator and a bit of additional circuitry to increment or decrement your digital potentiometer. The rate of increase or decrease in volume would be determined by the frequency of the clock generated by the 555.
    hgmjr
