soft i2c does not works
Discussion in 'Embedded Systems and Microcontrollers' started by sumani, Apr 29, 2009.
  1. sumani
    Mar 12, 2009
    8
    hi all
    for my project i wrote the following code and simulate through protest.
    void main() {
    int a;
    char txt[10];
    //Soft_I2C_Config(&PORTD, 3, 4); // Initialize full master mode
    lcd_config(&PORTB,1,2,3,7,6,5,4);
    TRISB = 0;
    PORTB=0;
    Lcd_Out(1,2, "Hello");
    Lcd_Cmd(Lcd_CURSOR_OFF);
    // Soft_I2C_Start(); // Issue start signal
    // Soft_I2C_Write(0xA0); // Address PCF8583
    // Soft_I2C_Write(0); // Start from word at address 0 (configuration word)
    // Soft_I2C_Write(0x80); // Write 0x80 to config. (pause counter...)
    // Soft_I2C_Write(0); // Write 0 to cents word
    // Soft_I2C_Write(0); // Write 0 to seconds word
    // Soft_I2C_Write(0x30); // Write 0x30 to minutes word
    // Soft_I2C_Write(0x11); // Write 0x11 to hours word
    // Soft_I2C_Write(0x30); // Write 0x24 to year/date word
    // Soft_I2C_Write(0x08); // Write 0x08 to weekday/month
    // Soft_I2C_Stop(); // Issue stop signal
    // Soft_I2C_Write(0xA0); // Address of eeprom
    // Soft_I2C_Write(0); // Write 0 to config word (enable counting)
    the software I2C doesnt works and if i enable Soft_I2C_Config(&PORTD, 3, 4);(uncomment) then the simulations strucks and even the LCD out put didin't come. don't care of the rest of the i2c codes. even still they are disabled and if i just enable only "Soft_I2C_Config(&PORTD, 3, 4);" line then there is no lcd output at simulations.
    hereby i've attached my microc code and protest file.please can any one explore this problem.
  2. CVMichael
    Aug 3, 2007
    416
    17
    I guess you are using the MikroC compiler ?
    If you look in the help for Soft_I2C_Config, it says: "Note: This library implements time-based activities, so interrupts need to be disabled when using Soft I²C"
    Then if you look for "Lcd_Config", it does not say if it's using interrupts or not, but logically it probably does...
    So, in this case, you probably have a conflict between the two because of this reason
  3. sumani
    Mar 12, 2009
    8
    yes i'm using microc complier. ok.. i got the point.so now what can i do for make it work? do you have any suggestions? is there are any compliers which overcomes this drawback?
  4. jvjtech
    Member
    Jan 26, 2008
    23
    I, too, will look up the MicroC compiler and libraries.
    Sumani: A schematic might help.
    Many problems with I2C come from three areas:
    - sensing the idle state of the two lines: SDA & SCL
    which at Idle should be High; code that waits for
    these lines to be high may hang if these lines
    never go high
    - incorrectly adressing the target device;
    - looking (or waiting) for the ACK or NACK from
    the target device;
    My apologies to MicroC as these issues are most likely addressed in the libraries.
    This information is provided to the forum as gerneralized comments for anyone wanting bit-bang their own I2C code.
    Regards: JJ
  5. CVMichael
    Aug 3, 2007
    416
    17
