So first?
Discussion in 'The Projects Forum' started by stanman11, Oct 11, 2011.
  1. stanman11
    Nov 23, 2010
    230
    So first I have to construct a circuit with my 10f200. figuring out where to put the diodes and resisters and such?
    Then do the coding and upload the code to the chip?
  2. iONic
    Nov 16, 2007
    1,422
    68
    O.K. That's good to know!
  3. nickelflipper
    Jun 2, 2010
    280
    35
    Gooligum has a good assembly language tutorial for the baseline chips. The 10f200 is the same the 12f508 in the example, except it has less ram and program memory than the 12f508.
  4. Markd77
    Sep 7, 2009
    2,803
    594
    It would probably be better to keep all these related threads together, perhaps one of the new mods would like to merge the threads?
    It gives people a chance to see the bigger picture.
    http://forum.allaboutcircuits.com/showthread.php?t=60095
    http://forum.allaboutcircuits.com/showthread.php?t=60107
    http://forum.allaboutcircuits.com/showthread.php?t=59353
    nickelflippers suggestion of tutorial looks good, and in one of the above threads I have suggested which components to use and how to connect them. In another thread I have put almost complete code.
    Also your sequence is correct:
    As a wise man once said "First comes the hardware, then the software."
  5. Georacer
    Nov 25, 2009
    5,151
    1,266
    Merging the threads isn't helpful, since the posts will be sorted chronologically, not by thread. Consequently, the answers will be mixed.
    The OP is advised to keep the threads dense in content, though.
  6. stanman11
    Nov 23, 2010
    230
    so most all every body knows my push button project.
    But if you dont
    Trying to accomplish a basic circuit with servo.
    1 button 1 servo
    button off center
    button on left
    button of center
    button of right
    So I was wondering if I got close here?
  7. KMoffett
    Dec 19, 2007
    2,584
    234
    Is 1.5V a battery?
    What is T1?
    What are the wires connected to on the Button?
    Ken
  8. Markd77
    Sep 7, 2009
    2,803
    594
    I don't know why you didn't continue this thread:
    http://forum.allaboutcircuits.com/showthread.php?t=60553
    I've already suggested a circuit in one of the other threads and if anyone had anything else to suggest they would have mentioned it.
    As to your circuit, it needs redrawing more clearly. The pins on the PIC aren't labelled, there are 4 wires going into a button, etc.
  9. Georacer
    Nov 25, 2009
    5,151
    1,266
    Threads merged for consistency.
  10. nickelflipper
    Jun 2, 2010
    280
    35
    1) Have a soldering iron, or access to one? I may have presumed you did.
    2) Is the 10F200 a 6 pin sot-23, or an 8 pin DIP?
    3) Downloaded MPLAB, and completed the first couple of the Gooligum lessons previously suggested?
    4) There are no shortcuts. Until the first led blinky program has been successfully completed, other projects should wait.
    5) The 28 pin demo board sent along could do this without a breadboard, just the hookup wire to the servo, and possibly the battery supply if the programmer can't supply 5V.
    6) Three AA primary (1.5V) batteries in series would need to supply the micro and servo. Alternate: four AA rechargeable (1.2V) batteries with a 1N400x diode in series could also work.
  11. stanman11
    Nov 23, 2010
    230
    I have a soldering iron and will be using the 8 pin.
    I have mplab and finding it alittle difficult to use when I have to chase the baby around all day.
    I have made a blinking Led with a 555 ic. made as small as I could.
    About nickle size.
    for now I will use and Debug with a 9v.
  12. Markd77
    Sep 7, 2009
    2,803
    594
    A 9V (PP3) battery isn't ideal for this. You can use it with a 5V regulator with the PIC and a few LEDs, but servos can use a lot of current (around half an amp when turning) and the PP3 battery has quite low capacity and high internal resistance so there could be problems. 3 AA batteries are much better.
