snubber in a SEPIC topology
Discussion in 'The Projects Forum' started by kender, Sep 30, 2011.
  1. kender
    Thread Starter Senior Member
    Jan 17, 2007
    263
    Colleagues,
    I’m building a SEPIC charger around MCP1631 controller. 3A charge current. I’ve examined several reference designs, and none of them had snubbers. As far as I can tell, they all were close to the ideal SEPIC topology.
    Could a SEPIC converter require a snubber? If so, I would design one in just in case. More generally, are there caveats in SEPIC converters that I should watch out for?
    Any suggestion, insight or reference is really appreciated!
    - Nick
  2. ifixit
    Distinguished Member
    Nov 20, 2008
    639
    110
    Hi Nick,
    Regarding the snubber...
    If your SEPIC design allows the inductor current to go to zero, then there can be ringing if there is no load on the inductor until the next charge cycle starts. This high frequency ringing usually causes no harm, but does increase the EM emissions from your circuit. A snubber can be used to suppress the ringing signal without effecting the efficiency too much. Your choice.
    Most likely your SEPIC design doesn't allow zero inductor current except maybe under an output short condition where the current limit circuit has kicked in. What does your design do?
    Regards,
    Ifixit
  3. kender
    Jan 17, 2007
    263
    My circuit is a 3amp battery charger. Space is at premium, so I'm planning to use as high of a frequency as my controller will allow, which should allow me to use smaller magnetics and capacitors.
    Would you recommend an RCD snubber in parallel with the upstream inductor (like in flyback converters)?
    I's rather design the snubber into the first version. If it will not be needed - all the better.
  4. ifixit
    Nov 20, 2008
    639
    110
    I cannot say for sure as I am not the designer, but you most likely don' t want a snubber if you are operating in the 100KHz to 1MHz range and don't care about EMI.
  5. kender
    Jan 17, 2007
    263
    To some extent, I care about the EMI. There's a possibility that this charger will become a part of a commercial product, which will be submitted to UL for testing. At the moment, I don't know which tests UL will run.
