Snubber Circuit for Serial/Parallel Solar Relay
Discussion in 'The Projects Forum' started by Mustang1965, Jul 14, 2016.
  1. Mustang1965
    Feb 20, 2013
    6
    I did look at a some of the threads here regarding the Snubber circuit, and did not come across one that I thought would meet my needs. Ok, before you tell me that I will not see any significant difference in automatically switching my 2 SOLAR panels (30 volt) between a SERIES circuit or a PARALLEL circuit automatically, I need to prove it to my self. It is just the way I am. So, I am including an attachment with the circuit. The relay I am struggling to locate is a "Break before Make" that will handle 10 Amps. I am looking at inserting a 30 amp Wind Turbine blocking diode, just in case there is a relay malfunction. What I am looking at is when the circuit is triggered to go from SERIES to parallel as the 20 amps will probably cause an arc between the relay contacts and the SOLAR charge controller (Morningstar MPPT TS- 60). I have a few of the blocking diodes from a previous project, so now I need to suppress the 20 amps when they switch from SERIES. I do not believe that the 60 volts (9 amps) will have an affect on the circuit as much as the PARALLEL design. Any thoughts and parts... Originally, was thinking of an MOV.
    Automating the switching will be done with either an Arduino or Raspberry Pi2, and measuring the current that is being generated by the panel(s), Will add a shunt to each of the panels to better make the decision as to PARALLEL or SERIES. Along with a photo cell in a frosted cup to measure the intensity of the sun/clouds...
    Thanks in advance for any assistance,
    Don
  2. BR-549
    Sep 22, 2013
    2,164
    415
    "Ok, before you tell me that I will not see any significant difference in automatically switching my 2 SOLAR panels (30 volt) between a SERIES circuit or a PARALLEL circuit automatically, I need to prove it to my self."
    How do you define difference?
  3. Mustang1965
    Feb 20, 2013
    6
    Panel output current.
    Should shading, dirt, clouds... cover one panel while wired in SERIES mode opposed to being wired in PARALLEL. Voltage should stay about the same...
  4. BR-549
    Sep 22, 2013
    2,164
    415
    So you're gonna make up the difference from when a cloud goes by?
  5. nsaspook
    Aug 27, 2009
    3,006
    2,348
    What is the required controller input voltage? What is the panel voltage. You don't want to switch live panels like that normally. If you have two panels strings make each string match the required CC input voltage.
  6. BR-549
    Sep 22, 2013
    2,164
    415
    I would suggest manually configuring and do some measurements and see what you get.
    JWHassler likes this.
  7. Mustang1965
    Feb 20, 2013
    6
    nasapook, I have 2 panels at the moment. The max allowed input voltage from the panels to the charge controller is 150 volts, and 800 watts on a 12 volt battery setup. In series they will be pushing 60 volts (10Amps) in parallel 30 volts (20 Amps. I am looking at automating the system based on current/TOD/shade, because one of the panels does get partial shade.
    Don
  8. nsaspook
    Aug 27, 2009
    3,006
    2,348
    What is your realistic expectation of power gains from this switching network?
  9. tom_s
    Member
    Jun 27, 2014
    287
    342
    or move the shady panel to somewhere not so shady
  10. Mustang1965
    Feb 20, 2013
    6
    Realistically, I have no idea as to what the power gains would be by automating the series/parallel configuration... I have always been curious as to what the answer would be and that is what has given me the incentive to try it in a project. The design portion was easy, it is the selecting the proper parts for the snubber circuit, that is the issue. I am thinking about putting a 1K to 2K micro Far.. capacitor across the contacts, to see if that would eliminate or reduce the arching...
    Moving a panel is not an option...
    Don
  11. BR-549
    Sep 22, 2013
    2,164
    415
    At what time of day does the singular panel block occur?
