SN75173 >45mA?
Discussion in 'The Projects Forum' started by owhite, Jan 29, 2014.
  1. owhite
    Jun 11, 2010
    Folks I'm using a differential line receiver (SN75173) and it's drawing 45mA which seems like it's a lot higher than suggested from the specs.
    The circuit is here.
    At present the connections to the bus that serve as inputs are not connected to anything. The outputs (pins 3, 5, 11, and 13) are connected to an I/O board plugged into the PCI slot of a computer.
    Any suggestions for why the draw is so high? I have a few of these in my circuit and I just surprised by the overall current. I'm using proteus software which supports circuit modeling and it's reporting that the draw should be much lower.
    thanks,
    owen
  2. crutschow
    Mar 14, 2008
    13,501
    3,375
    What are the loads on the outputs? Could they be low impedance, such as 75 ohms?
  3. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,696
    1,297
    From the TI datasheet, the max static current is 70 mA with the outputs disabled. I've used similar parts; they are hungry and they do run warm.
    ak
    #12 likes this.
  4. owhite
    Jun 11, 2010
    Thanks - I was just mis-reading the spec sheet - looks like 45mA is not too unreasonable.
