hi
my question again is about smt160.
i wanna use 4 sensors with an atmega16.first i tied to connect their outputs to the input pins of a 4:1 MUX.and the output of the MUX to INT0 of the micro.
but it didn't work properly.then i found out that the mux can't pass the wave generated by the sensors to the micro with their original shapes and that's why i got no correct result.
then i decided to change the hardware.i connected all the sensor's output to the INT0 and their vcc to 4 different pins of micro to on & off them in sequence.again it didn't work.
now i'm thinking about using different external interrupts.but the problem is that i've only 3 timers to measure the dutycycle.
is there any software solution to this or i've to change my micro.
and what avr micro has 4 timers.
thanks
thanks
