smps
30,794
Or buy a second 24V/20A SMPS and wire the two in series (on the condition that the supply outputs are floating).
The bonus is you now have a 48V/20A supply.
Dodgydave
Joined Jun 22, 2012
11,301
unless you have the circuit diagram its going to be a bit difficult to modify it, the output would probably squeeze to 35v at best..
bountyhunter
Joined Sep 7, 2009
2,512
You will also need new magnetics components and all new output components (rectifiers/filter caps, etc) since they won't be rated high enough for double output voltage.
