SMPS
Discussion in 'The Projects Forum' started by soda, Nov 26, 2009.
  1. soda
    Thread Starter Active Member
    Dec 7, 2008
    174
    13
    Hi all members,
    I want to use a smps to power a large display. The display use 12v@4Amps.Can anybody please tell me how to turn on the smps without a pc. Which wires on the smps do i need to connect to start the smps and also, is there some more things to do to use the smps as a psu.
    Thanks for all your help,
    Soda
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
  3. soda
    Dec 7, 2008
    174
    13
    I live in South Africa and thanks for the advise.I would still wanted to know what terminals on a computer supply you have to bridge to enable it to start on it's own. SA supply is 240vac.
    Soda
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
  5. Tahmid
    Jul 2, 2008
    344
    27
    soda,
    To start the PC PSU without the PC, you need to connect the Enable Wire (the green one, usually, mind it, there should be only one green wire) to Ground (the black ones, connect the green one to any one black one). Done. Your power supply is ready to go.
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  7. soda
    Dec 7, 2008
    174
    13
    Bill, Tahmid and Sgt Wookie, many thanks for all the help. You all did a grate job in helping me. I know now, i will be able to do it.
    Soda
