SMPS voltage and curent control
Discussion in 'The Projects Forum' started by roro36, Oct 1, 2010.
  1. roro36
    Sep 7, 2010
    I'm using microcontroller to control my switched mode power supply. Is it ok to use 2 ADCs to measure the output voltage and current for use in voltage and current limiting? Will this work or do you have to use analoge components? I'm not to worried about the delays involved, i will deal with those.
  2. windoze killa
    Feb 23, 2006
    I can't see any reason why you can't. So long as you have the correct voltage and current sensors that the ADC can use.
