SMPS Tutorial
Discussion in 'Electronics Resources' started by Guilngan, Jan 26, 2008.
  1. Guilngan
    Jan 26, 2008
    9
    I am a trainee electronic technician in a organisation.....Looking for some strong basic concepts of how smps works and how to repair them....Thanks
    Best Regards
    Guilngan
  2. chesart1
    Jan 23, 2006
    269
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I suppose that the "strong basic concepts" are the opposite of the "weak basic concepts". I would start with the basic operation of the inductor. If you don't have any calculus then this one is going to be tough, but the basic idea is that a voltage can be created from a changing current. If you change the current very slowly then there is almost no voltage generated. If you try to change it rapidly, like with an on/off switch, then you can generate large voltages. This, in a nutshell, is THE fundamental concept of the SMPS.
    Code ( (Unknown Language)):
    1.
    2. V = L * di/dt
    3.
    4. where V is the voltage across the inductor
    5.       L is the inductance
    6.       di/dt is the derivative or time rate of change of the current
    7.
    8.
    Sgt.Incontro and onlyvinod56 like this.
  4. Guilngan
    Jan 26, 2008
    9
    Hi All,
    Thanks for your help....will start reading-up on this materials.
    Regards
    Guilngan
  5. x2pher
    Jun 6, 2008
    Hi guilgan,
    Im a new member of this forum.Interested also in SMPS.
    I suggest to read first basic converter theory and familiarize wit the circuits construction.
