SMPS transformer?
Discussion in 'General Electronics Chat' started by 1-3-2-4, May 15, 2013.
  1. 1-3-2-4
    Thread Starter Active Member
    Dec 26, 2008
    194
    One side has 4 pins and the other side has 6 and below it it shows:
    O/P:5V/0.15A
    12V/3.6A
    I don't know what wires to check.. what should I be looking for as far as voltages going to it?
  2. JayArr
    Mar 11, 2013
    14
    Those are the specs for the power supply not the transformer.
    The transformer will likely have some form of 50KHz 160V/380V duty cycle modulated square wave on the primary and lower voltage square waves of the same freq on the secondary.
  3. 1-3-2-4
    Dec 26, 2008
    194
    Anyo one of the 4 legs on the primary side should give me like 160V and I should be looking for less on the secondary side right?I wonder if I'm not getting anything I think I found a shorted diode but not 100% sure yet.
  4. kubeek
    Sep 20, 2005
    4,686
    805
    Everything really depends on what the hell you are trying to do with it, doesn´t it?
  5. 1-3-2-4
    Dec 26, 2008
    194
    I would think so...
