If it has more than one winding, burned enamel is pretty much guaranteed to allow shorts between windings.suppose it is burned how to replace it???mh??
only testing equipment is multimeter....when i checked solder joint i found this coil is dislodged as if solder joint has been melted...i take it out because some turns of coil seems to be dark brown... and to take phot of it...only this clarity is available ...my cam (2mp)do not have flash (will try to take it in sunlight)....Yeah the photos are terrible. You need to set your camera to "macro" setting and use a bright light.
Why did you remove that transformer? With so few turns (and thick wire) it is extremely unlikely to have failed. You can test ohms to see if it is shorted between winding, but I really doubt it will be.
What about the solder joints I mentioned in post #14? After the caps the next most likely cause of a heat fault are the solder joints on the power components, which you need to inspect with a magnifier. After that you start replacing power components.
Do you have any test equipment?
Did you test it with a load attached?
Rather than try to identify the core material for replacement - its probably better to try rewinding it - do a *VERY* detailed sketch to show the sense and position of each winding.
That's just dark brown varnish it is dipped in. We used the same murky dark stuff in a motor rewinding shop I worked in.
Those toroid transformers don't blow, they are used to generate a low power secondary voltage rail, often the -12v rail. The main SMPS transformer is the big yellow ferrite block one in the middle of the PSU.
Some of those voltages are a bit off - calculate how many % off they are.ok...now i reconnected coil and checked all solder joints....now it works....but o/p voltage at blue wire is -10.86V instead of -12v..
@ 12v i get b.w 11-12v range (<12v)
@ 3.3v ---3.06v
@5v ----5.86v
shall i connect to PC????
If that is running with no load, those voltages are fine. The 5v rail is high because it is struggling to regulate with no load attached, and the other rails are low because the duty cycle is cranked right down (because it is trying to regulate the 5v)....
@ 3.3v ---3.06v
@5v ----5.86v
by Jake Hertz
by Aaron Carman
by Don Wilcher
