SMPS in parallel with linear reg
Discussion in 'General Electronics Chat' started by stoopkid, Aug 26, 2012.
  1. stoopkid
    Mar 3, 2011
    136
    I want to completely bypass the micro USB plug and linear regulator on my Raspberry Pi and replace it with a SMPS and barrel jack. Can I simply put the SMPS in parallel with the linear reg or do I have to remove the linear reg? I'm just wondering if having no higher voltage but a capacitor to bleed into if the linear reg would bleed backwards or something.
    Thanks.
  2. kubeek
    Sep 20, 2005
    4,687
    805
    You should take the linear reg out.
  3. #12
    Nov 30, 2010
    16,665
    7,313
    The right way is to isolate them from each other with diodes but, that is going to mess with the voltage available by a significant amount. Do what kubeek said.
  4. stoopkid
    Mar 3, 2011
    136
    Thanks guys
