I am working on a smps for a yamaha mixer/amplifier. Normally I sub out any problems with smps but as this is my own unit I am undertaking, with great caution, the repair myself - I prefer working on older items with real transformers etc-
I have tracked the fault to the IGBT transistor 1MBK50D-600v. Using my normal channels I cannot source a direct equivalent part number, however after some digging about I have come across a part by Fairchild HGTG30N60A4 which 'appears' to be a slightly higher spec and believe it could be what I am looking for. There is a difference of £20 in my favour should this be so.
Has anyone any other ideas or faced this problem ?
I would rather pay £5 and be wrong about my diagnosis than £25.
The initial fault was the start-up resistors would blow when switched on, but no fuses.
Also are there any recommended publications regarding smps recommended? I would rather repair these myself than sub out (3-4 per month)
Regards All + thanks in advance
