If ANYONE sees a request like this, please report it using the report button :3. Copyrighted material. When referencing copyrighted material, please provide the relevant credit. In some cases, an intellectual property owner may require they give you permission before you can reprint or reuse their work. In most cases, a link to the original source is acceptable, if applicable.
Please do not make requests for, or post links to, material that otherwise contravenes the conditions of the original or subsequent author's copyright. All instances of such requests will be met firstly with a warning, and secondly with a ban. If you are in doubt raise the issue with a Moderator or Administrator.
