SMPS blast
Discussion in 'General Electronics Chat' started by RRITESH KAKKAR, Dec 23, 2015.
  1. RRITESH KAKKAR
    Thread Starter Senior Member
    Jun 29, 2010
    2,831
    89
    I have selled LED Sign the customer said that the sound came from it of blast.
    I open the fuse of 15A was broken.
    I short the fuse the whole board get blast even IC of 8 leg and resistor black out.
    Why it happen??
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,383
    RRITESH KAKKAR likes this.
  3. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    But now it is blast.
    I was thinking that it will work by shorting or changing fuses.
  4. sailorjoe
    Member
    Jun 4, 2013
    361
    63
    Well, Rritesh, off hand it seems clear that the circuit developed a short somewhere. The fuse blew, which kept the good part of the circuit still intact. When you shorted the fuse, all the protection was removed, and some parts overheated and blew up or burned up. I did that once in a TV and it caught fire. Flames going up three feet. Lots of fun, but not helpful as a diagnostic technique.
    Maybe the 8 pin IC developed an internal fault and started to draw too much power but the fuse blew. Maybe another component, like a transistor, failed and pulled too much power through the 8 pin IC.
    I'd say the board is toast (that's the technical term <grin>). To fix it now is a lot of work. Do you still want to try?
  5. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    yes, new board cost very much
    5V 10A
  6. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Hello Derstrom, Experience was true when you don't know the work you will be fired out.
  7. Dodgydave
    Jun 22, 2012
    5,133
    767
  8. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    I have no idea of this.
    anyway, i am going to buy new.
  9. Dodgydave
    Jun 22, 2012
    5,133
    767
    Just goes to show how little you know in electronics...
    I rest my case your honor..
    #12 likes this.
  10. nerdegutta
    Dec 15, 2009
    2,565
    805
    Just curious;
    230vAC in and 5vDC 10A out?
  11. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
  12. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Curious for what?
    It convert but how i don't know.
    I can use transformer.
  13. nerdegutta
    Dec 15, 2009
    2,565
    805
    I am wondering if the input is 230 volt alternating current and the output is 5 volt direct current, capable of delivering up to 10 Ampere?
  14. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,383
    Looking at the PCB it says 3.15A at the fuse and NOT 15 A.
    This is already quite a difference.
    Bertus
  15. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Sir, You have eagle eyes.
    i can't see properly from pic but you have.
    anyway, it was T3.15A
  16. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    According to name it convert the AC to DC with converter.
  17. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    link
  18. nerdegutta
    Dec 15, 2009
    2,565
    805
    OK.
  19. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    He is explaining nice.
  20. nerdegutta
    Dec 15, 2009
    2,565
    805
    A simple yes or no would be enough. I know how it works.
    Now you know!
    I got my answer.
