Smoke Detector
Discussion in 'The Projects Forum' started by chal-lo, Sep 12, 2012.
  1. chal-lo
    Sep 10, 2012
    6
    Hi there,
    I am starting with IC Electronics and was trying to decipher how a smoke detector works. The manufacturer is Electro DH and the model name is 50.606. I have searched for a diagram but haven't found any.
    My problem is that I am trying to identify the Logic Family chip in the middle. I have tried to read it but I don't reach it. Any ideas?
    I provide a picture to see if anyone manages to figure it out.
    Many thanks in advance.
    Chal-lo
      File size:
      301.8 KB
      44
  2. wayneh
    Sep 9, 2010
    12,391
    3,246
    Get a bright light and a magnifying glass to see if you can read the markings on the IC. Sometimes you can only read them at just the right light angle.
    I would have guessed quad op-amp or comparator, but it's got too many pins for that.
  3. #12
    Nov 30, 2010
    16,704
    7,354
    In today's world, it could even be a tiny microprocessor.
  4. chal-lo
    Sep 10, 2012
    6
    Well I tried to do so, but it seems to be already partially scratched and reach to get only like 1 or 2 digits.
    thanks any way.
    Perhaps any other circuit for which I could get a diagram would be valid. Do you know of any reliable circuit?
    Many thanks for your help.
    Chal-lo.
  5. KMoffett
    Dec 19, 2007
    2,584
    234
    Google: smoke detector IC
    You might be able to reverse engineer the PCB layout to a schematic, and then compare component connections to the datasheets for the various smoke detector IC listed in Google.
    Ken.
  6. BMorse
    Sep 26, 2009
    2,675
    234
    You are not going to see or read the part number off of the IC, since the manufacturer of the smoke detector seems to have wiped/scratched it off so people can not do exactly what you are doing, reverse engineer it. A lot of manufacturers will do that to prevent people from figuring how it works or what devices they used.....
  7. ScottWang
    Aug 23, 2012
    4,933
    777
    if you want to know more about the model 50.606, then you should do as KMoffett said at the #5.
    The following circuit was copy link from another Big5 forum in Taiwan.
    http://gc.digitw.com/new_page_21.htm
    #12 and absf like this.
  8. wayneh
    Sep 9, 2010
    12,391
    3,246
    An LM358 doesn't have 16 pins. ;)
  9. ScottWang
    Aug 23, 2012
    4,933
    777
    I didn't mean that the IC of the circuit that I linked is equal to the model 50.606, it just shows that used another way to completed the same function.
    The circuit that I linked, it's working good, because I did take care some people's problem.
    There is another smoke detector used 16 Pins IC.
    RE46C190 photoelectric smoke detector
    http://electroschematics.com/2545/smoke-detector-circuit/
  10. MrChips
    Oct 2, 2009
    12,638
    3,456
    The IC is a Photoelectric Smoke Detector made by Motorola (now Freescale), MC145010 or MC145011.
  11. absf
    Dec 29, 2010
    1,493
    374
    Could it be MC145012? I traced the circuit and P11-R13-LED-Vcc. Datasheet attached.
    I think the OP turned the PCB over, take a photo and mirrored the picture so the pin 1 of the chip alligned to the right of the PCB... Very smart...:D:cool:
    Allen
