Smoke and fire alarm sensor
Discussion in 'The Projects Forum' started by RRITESH KAKKAR, Aug 19, 2013.
  1. RRITESH KAKKAR
    Thread Starter Senior Member
    Jun 29, 2010
    2,831
    89
    i need to make a fire and smoke detector security system...
    I have done using NTC and bimetallic strip in school days now i want to make it more sensitive so, please tell is there any chance to make it homemade??
  2. WBahn
    Mar 31, 2012
    18,092
    4,918
    For YOU to make it homemade? Pretty much... no.
  3. WBahn
    Mar 31, 2012
    18,092
    4,918
    But, I'd love to hear how you used an NTC resistor and/or a bimetallic strip to detect smoke.
  4. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    heat detection near it...any suggestion for making or buying...
  5. WBahn
    Mar 31, 2012
    18,092
    4,918
    Gee, I didn't realize that smoke was all that hot.
    My suggestion is that you buy. In fact, you should buy a complete system according to the recommendations of a professional and have them install it.
  6. Bernard
    Aug 7, 2008
    4,243
    420
    I built smoke- fire detector [ 1972 ] using a Figaro T. G. S. # 109, gas detector. In side by side comparison it beat out a comercial smoke detector by several minutes but it required more operating power. It would trip on 250 ppm of propane. At one time R.S. carried the sensor.
  7. ScottWang
    Aug 23, 2012
    4,933
    777
    Using a LDR(CDS) can be a smoke detector, when the smoke didn't caused by the gas.
    Using NTC resistor to detect when the heat reach to some setup level.
    Using the gas detector to detect when the gas have any leakage.
  8. strantor
    Oct 3, 2010
    4,302
    1,989
    I ran across these turbidity sensors for washing machines a while back while looking for optical sensors. Maybe if they can detect turbid water, they can detect turbid air?
  9. ScottWang
    Aug 23, 2012
    4,933
    777
    I think the turbid air can be detected by the turbidity sensors.
    Detecting the turbid air as smoke, turbid water, whatever you are using LDR(CDS) or IR or photo transistor, the theories are the same.
  10. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Bernard likes this.
