SMDCodes
Discussion in 'General Electronics Chat' started by Jotto, Nov 9, 2011.
  1. Jotto
    Apr 1, 2011
    159
    17
    As you know lately schematics and parts list for the industry has severely decreased over the last 10-20 years. Most of the time I troubleshoot without them, but sometimes you do need them when crossing parts.
    I find that crossing SMD components is very difficult because of the limited information printed on the component. They are difficult to read is the first problem, second being the lack of uniformity of the manufactures. Cross reference lists are incomplete and misleading.
    I have a unit that appears to have 3 SOT23-3 case styles, I am assuming they are bad. The problem I can't find any thing close to the listed letters on the component.
    I will list them below, the capital letters are the ones listed across the case, lower case is the ones listed sideways on the component.
    PJ bf crossed to BB159
    ZCA bh
    NJ dd
    I have a few of these boards, and all the small letters that are sideways are different on each board, so I am guessing this is a manufacture date code.
    If anyone has a good site for crossing these parts it would be a great help to me.
    Thanks Jim
  2. R!f@@
    Apr 2, 2009
    8,791
    771
    can u post a picture ?
  3. Jotto
    Apr 1, 2011
    159
    17
    Don't think that will help you much. You won't be able to read anything. But I will bring in a high resolution camera and take a picture of it. Even with high resolution I doubt you will be able to read anything.
  4. nerdegutta
    Dec 15, 2009
    2,567
    806
    Does the camera have a "macro" setting. If so, it can take really sharp pictures really close.
  5. Jotto
    Apr 1, 2011
    159
    17
    yes I have a high end slr digital camera by canon. But that isn't the problem, the problem is you have to tilt the board to read the components.
  6. nerdegutta
    Dec 15, 2009
    2,567
    806
    Oh, so it's one of those: "Hard to get at component?"
    I see.
  7. Jotto
    Apr 1, 2011
    159
    17
    No they are easy to see, its just not easy to see the markings without tilting the board.
  8. t06afre
    May 11, 2009
    5,939
    1,222
    I have the Turuta 2011 edition SMD-codes databook. http://www.turuta.md/
    ZCA may be the KN3904s
    NJ may be one of these
    NJ KRC109S Si-npn-Digi Sw, 50V, 100mA, 200mW, 200MHz, R1/R2=47k/22k SOT-23 16ta - 3f Kec
    NJ KRC409 Si-npn-Digi Sw, 50V, 100mA, 100mW, 200MHz, R1/R2=47k/22k SOT-323 16ta - 3f Kec
    NJ KRC409E Si-npn-Digi Sw, 50V, 100mA, 100mW, 200MHz, R1/R2=47k/22k SOT-490 18ta - 3f Kec
    NJ KRC409V Si-npn-Digi Sw, 50V, 100mA, 100mW, 200MHz, R1/R2=47k/22k VSM 18ta - 3f Kec
    nj PT7M6249NLC3 Vdet-IC 4.9V±1.5%, -Reset ODO SC-70 16vdc VD6 3b Pti
    nj PT7M6249NLC3E Vdet-IC 4.9V±1.5%, -Reset ODO, Lead free SC-70 16vdc VD6 3b Pti
    nj PT7M6249NLTA3 Vdet-IC 4.9V±1.5%, -Reset ODO SOT-23 16vdb VD6 3b Pti​
    nj PT7M6249NLTA3E Vdet-IC 4.9V±1.5%, -Reset ODO, Lead free SOT-23 16vdb VD6 3b Pti
