i have been working on a LCD monitor it apers to have 2 bad ribbon wires from the screen to the controler for it. i put solder on the pads after cleaning them off then figured put wire over heat and it would be fixed. however i have tryed heating them with varying sizes of solder iron with not much luck getting it to solder. i know sombody with smd tools to do it but wont see him for a while, he has a special IR lamp that is temp controled in order to melt the solder. so i was thinking maybey somthing like a heat gun or a small gas torch near it. this is hard to solder because the ribbon is a thin plastic with wires in it and plastic between the solders at the end of the wire and the outside. it has to melt the solder but not hurt the plastic so far none of my atempts have done anything to the plastic so it seems to be prety hight temp tolarance. not sure the IR light would even do it because thers plastic between the solders and where it would be.
