SMD reverse voltage protection diode
Discussion in 'General Electronics Chat' started by Dritech, May 29, 2016.
  1. Dritech
    Sep 21, 2011
    756
    5
    Hi all,
    I am doing my first project with SMD components. The circuit consumes around 200mA (MAX) of current and has a 5V voltage regulator. For reverse voltage protection of the circuit I was planning to include a diode at the input of the regulator.
    From the two diodes below, which would be best for this application? Since the CD1206-S01575 has a forward current of 150mA, will it work?
    Bourns CD1206-S01575
    Comchip Technology ACDBN140-HF
  2. dl324
    Distinguished Member
    Mar 30, 2015
    3,367
    642
    From the information given, the Schottky rectifier would be better.
  3. Bordodynov
    May 20, 2015
    669
    194
    Better or worse than the Schottky diode is determined by the input and output voltage. If the input voltage is substantially higher than the output voltage and the suitable silicon diode. If the input voltage is slightly higher than the output voltage, it is necessary and Schottky diode or MOS-transistor. For example, if the input voltage may drop to 5.5V, the regulator needs with small falls (LowDrop). By the way there are regulators with PNP transistor, which are not afraid of the negative input voltage. For example LT1763IS8-5 # PBF
