SMD Resistors
Discussion in 'General Electronics Chat' started by Dritech, Sep 13, 2014.
  1. Dritech
    Sep 21, 2011
    756
    5
    Hi all,
    I have a PCB with SMD components. I noticed that there are many resistors is parallel. For instance, two 300ohms SMD resistors are used as a current limiter for an LED. Why is that? Why they did not use a single resistor?
    Thanks in advance.
  2. ISB123
    May 21, 2014
    1,240
    531
    You mean voltage divider connection?
  3. ericgibbs
    Jan 29, 2010
    2,575
    389
    hi Dri,
    Its possible the dissipation in a single SMT of that case size, does not have the required heat dissipation, so two, of double the resistance value are connected in parallel.?
  4. ISB123
    May 21, 2014
    1,240
    531
    If they are connected in series then they probably had lots of 300 Ohm R but didn't have any 600 Ohm R so they connected them in series to save on budget?
  5. Dritech
    Sep 21, 2011
    756
    5
    Thanks for the replies. Ericgibbs answer makes sense for the LED current limiter resistor since this PCB is powered using 12V without a regulator.
    But I also noticed the same technique used with buttons. This PCB has surface mount buttons which are resistance coded (for instance when button A is pressed it outputs 300ohms... when button B is pressed it outputs 600ohms etc.). In this case power is not an issue since it will most probably be connected to a voltage divider and to an ADC. So in this case why are they connected in parallel? could it be budget wise or to increase efficiency when placing the SMD components?
