SMD Resistor Values
Discussion in 'General Electronics Chat' started by Lee Chris, Oct 13, 2015.
  1. Lee Chris
    Oct 12, 2015
    9
    I have a simple question:
    Is there specific resistor values for SMD resistors similar to those values on normal carbon resistors?
    Where can I find this list of values?
  2. blocco a spirale
    Jun 18, 2008
    1,462
    370
    Google "SMD resistor values".
  3. Lee Chris
    Oct 12, 2015
    9
    Thanks!
    I'm seeing values as granular as these. Are they normal for SMD?
    4.7
    5.1
    5.6
    6.2
    6.8
    7.5
    8.2
    9.1
    10
    10.2
    10.5
    10.7
    11
    11.3
    11.5
    11.8
    12
    12.1
    12.4
    12.7
    13
    13.3
    13.7
    14
    14.3
    14.7
    15
    15.4
    15.8
    16
    16.2
    16.5
    16.9
    17.4
    17.8
    18
    18.2
    18.7
    19.1
    19.6
    20
    20.5
  4. OBW0549
    Mar 2, 2015
    1,396
    941
  5. MikeML
    Oct 2, 2009
    5,451
    1,066
    Or go to DigiKey.com or other industrial supplier.
  6. shiva007nand
    Member
    Sep 25, 2015
    38
    make sure tolerance for SMD components value,
    example 104 means 100 K Ohm with +-5% of tolerance
    and 1004 means 100 k ohm with +-1% of tolerance.
  7. Papabravo
    Feb 24, 2006
    10,340
    1,850
  8. Roderick Young
    Member
    Feb 22, 2015
    408
    168
    It costs about the same to make a 1% SMD resistor as a 5% one, so generally, what we would do for product design is specify 1% resistors, but if possible, choose from a preferred set, so that less resistors needed to be stocked. You can look up E96 resistor values here http://www.radio-electronics.com/info/data/resistor/e-series-e3-e6-e12-e24-e48-e96.php to see the standard ones. 6.81k, for example, was a preferred value, because it closely matched the old 6.8k of 5% and 10% resistors. If a design needed 6.5k, we would try to see if it would tolerate 6.81k, before using 6.49k, even though 6.49 was technically a standard value.
    If you're ordering individual resistors from (say) Mouser, you'll see that the 1% ones do not cost more, and moreover, that it costs almost the same to buy 10 resistors as 1 (because it's all handling charge for something so cheap).
  9. crutschow
    Mar 14, 2008
    13,509
    3,385
    The available resistor values depend upon the tolerance of the resistor.
    ±1% resistors have many more values that ±5% types.
    The list you posted is for ±5% resistors.
  10. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    InspectorGadget likes this.
  11. OBW0549
    Mar 2, 2015
    1,396
    941
    Good point. And sometimes, in cases where using a 1% resistor instead of 5% can eliminate a trimming operation or a calibration step, they actually can be cheaper than the 5% part. The same goes for 0.1% resistors, which are not terribly expensive anymore.
  12. RichardO
    May 4, 2013
    1,342
    431
  13. kubeek
    Sep 20, 2005
    4,691
    806
    They will not match because many of the values are rounded off.
