SMD LED with forward voltage less than 1.75V
Discussion in 'General Electronics Chat' started by Jyothics23, Sep 2, 2008.
  1. Jyothics23
    Sep 2, 2008
    Hi All,
    I am looking for SMD LED, case style 0603, with forward voltage less than 1.75V. I tried to find from internet but i couldn't get it.If anybody know such kind of LED available, pls provide the information.
    Appreciate your replays
    Joo
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  3. Audioguru
    Dec 20, 2007
    9,411
    896
    Infrared LEDs have a low forward voltage. Maybe only 1.4V.
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I stumbled across one on Mouser.com the other day, but not knowing where you are, I don't know if you could order it. Besides, I didn't save the part number. They do sell them though. I believe it was a red LED.
    You'll be hard-pressed to find a visible light spectrum 0603 LED that has a typical Vf of under 1.6v.
  5. rezer
    Member
    Aug 26, 2008
    10
    He probably wants to see the light.:)
    Red LEDs will typically drop less voltage and with the proper current considerations you could get close to 1.6V but probably not lower than that. If you up the current limiting resistor to decrease the Id to around 3mA, this will put your Vf around 1.7-1.8V. The trade-off is, your LED won't be as bright, but bright enough.
    Michi_LEE likes this.
  6. Jyothics23
    Sep 2, 2008
    Hi rezer, SgtWookie, Audioguru, bertus,
    Thanks to all of you to help me to find the item .:)
    Appreciate your work.
    Regards,
    Joo
