SMD electret microphone
Discussion in 'General Electronics Chat' started by tufty88, Sep 28, 2013.
  1. tufty88
    Jul 16, 2010
    8
    http://uk.farnell.com/kingstate/kecg2742tbl-a/microphone-electret-condenser/dp/1502744
    These electret microphones with no pins- can they be soldered directly to a PCB? or are they intended to have wires added to them (not pcb mount).
    I am asking, to see whether these can be used on PCB, instead of mic with through hole pins- as I believe it is cheaper to use SMD instead of through hole in manufacturing process?
    Thanks,
    Jonathan
  2. #12
    Nov 30, 2010
    16,704
    7,354
    They are designed to be surface mounted but, if you're good with a soldering iron, you can attach wires.
  3. tufty88
    Jul 16, 2010
    8
    Thanks mate! makes sense to me
