SMD diode
Discussion in 'General Electronics Chat' started by cryosar, Sep 11, 2009.
  1. cryosar
    Thread Starter Active Member
    Apr 2, 2009
    40
    Whether anybody have the datasheet for 1N5408 SMD diode? If so pls help me.
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    To my knowledge the 1N5408 is only available in lead versions.
    These are housed in DO201 , DO27 or DO15 packages.
    Greetings,
    Bertus
  3. cryosar
    Apr 2, 2009
    40
  4. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    On the page there are three package names given.
    Wich one are you looking for?
    SMA , MELF , SMB or SMC.
    Greetings,
    Bertus
  5. AlexR
    Jan 16, 2008
    735
    54
    As Bertus stated the 1N5408 only comes in a leaded package.
    If you must have a SMD take a look at the S3M from Fairchild, Same current and voltage specs as the 1N5408 but in a surface mount package.
    http://www.fairchildsemi.com/ds/S3%2FS3M.pdf
