Reverse polarity protection to what?!Hi all,
Can an SMD reverse polarity protection diode be damaged by ESD? If yes, can this parameter be found on the diode datasheet?
ESD is (hopefully) low energy and can't cause enough heating effect to melt bits off of switch contacts, but its more than enough to punch through the delicate gate layer in MOS devices.Thanks for the replies.
Another quick question. Can a microswitch similar to the one in the link below be damaged from ESD?
http://cpc.farnell.com/1/1/9952-microswitch-v4-pcb-plunger-ss5d-omron.html
If no, why is that? If ESD can reach high voltages which exceeds the switch rating, why it would not be damaged?
Thanks in advance.
by Duane Benson
by Jake Hertz
