SMD Component identification
Discussion in 'General Electronics Chat' started by nlan, Sep 11, 2012.
  1. nlan
    Sep 11, 2012
    First of all greetings from a fellow sparky from Greece. Should have joined this community alot sooner!
    Here I have this component on this PCB which I can't figure what it is..
    Perhaps someone more experienced could help!
    Thanks in advance
  2. absf
    Dec 29, 2010
    1,493
    374
    The 6 smaller ones are resistor and the bigger ones are capacitors.
    Allen
  3. nlan
    Sep 11, 2012
    Hi Allen
    The component I'm enquiring about is the one in the middle, and doesn't look like any capacitor i've seen. I'm quite sure it isn't one..
    Maybe some kind of fuse, or something??
  4. absf
    Dec 29, 2010
    1,493
    374
    I zoomed your picture 200% but I still cannot recognize what it is. Perhaps you can either take another picture of it sideways or describe the component in your own words.....:)
    Is it the component pointed by red arrow?
    Do you have another identical board for comparison?
    Allen
  5. MrChips
    Oct 2, 2009
    12,622
    3,451
    Tell us where the PCB is from.
  6. ErnieM
    Apr 24, 2011
    7,433
    1,623
    If you are referring to the component with the black rectangle in the center it looks like a resistor. The two lines thru it are where a laser cut thru the resistor material to trim the value into spec, which is typical for SMD resistors.
  7. nlan
    Sep 11, 2012
    It does have the same resistance of 20ohm both ways, so I guess it might as well be a resistor.
    I just never have come across one that looked like this.. Kinda transparent, almost like an LED.
  8. nlan
    Sep 11, 2012
    The pcb comes from my Land rover's fan ECU.
    Controls the engine fan speed by a PWM signal coming from the main ECU.
  9. MrChips
    Oct 2, 2009
    12,622
    3,451
    oops. Delete your reply real quick.
  10. ErnieM
    Apr 24, 2011
    7,433
    1,623
    As far as I see, he's just looking at his car. I do not see any modifications being done here.
    We don't have any restrictions on education in the TOS, do we?
  11. t06afre
    May 11, 2009
    5,939
    1,222
    This is not a modifaction thread. It is a repair thread. Hence it should be OK.
