One of the best ways of narrowing down SMT parts is to determine the manufacturer from the logo, which even in SMT parts is almost always stamped or etched into the top of the plastic part. Then, its easy to find sites that show the logos of all semiconductor and electronic part manufacturers. Once you've determined the mfg, and you have the marking, you're 90% there and if all else fails, call the manufacturer and ask the customer service people or the applicfation engineers.
I couldn't find the manufacturing logo anywhere; it looks like a flipped-up Lexus logo without the circle around it. The properties of the three terminals are - two have 230ohm both direction and no reading on the third. Checking a good device with a Huntron I only see the 230ohm and no junctions on any of the terminals. In the circuit the two terminals next to each other are connected together, the device sits parallel in the base emitter junction of an IGBT.
Thank you for these sites, all good links however for the life of me I still cant identify the SMT markings, nor can I figure out what type of component it is.
To find out if its PNP or NPN and the necessary upper voltage tolerance you'll have to look closer at the circuit layout.
This based on the knowledge that the gate of a MOSFET is electrically isolated from the source and drain. So it makes sense that there's no reading on the third pin.
Mosfets are neither NPN nor PNP, mosfets are N or P. And you seriously think that if it really were a mosfet, that it would have the current rating marked on it? And why not voltage rating?
